Stick Welding Guide - How-To | MillerWelds
Stick Welding Guide
Stick welding tips, training materials, weld calculator and more. Learn how to Stick weld or improve your skills with Miller Stick welding resources.
Stick Welding Calculator
Articles and Videos
Learn How to Save Time and Money on Any Jobsite With a Welder/Generator
Save time and get work done faster on the jobsite with new technologies and Miller® welder/generator solutions.
Read More
The Right Filter Makes a Difference in Weld Fume Management
Choosing the appropriate filter media can help increase productivity and profitability by lowering downtime, improving airflow and reducing filter replacement costs.
Read More
Eastfield College Plans to Expand Welding Fabrication Offerings
The college hopes to soon expand its program to offer a certificate in welding fabrication, due to industry demand in that area.
Read More
New Speed-Governing Tech for Engine-Driven Welder-Generators Improves Fuel Efficiency and is Quieter
The welder/generators in this engine category will idle when there is no load applied to the engine and ramp up to a full speed of 3,600 rpm when any load is applied, no matter how much power is actually needed.
Read More
Engine-Driven Welder/Generators with Dual-Operator Capabilities Save Space and Fuel
A diesel engine-driven welder/generator with dual-operator capabilities is one tool that offers the versatility to help accomplish what you need to get done in today’s working environment.
Read More
How to TIG Weld Aluminum, Plus MIG Weld, With One Multiprocess Welder
The Dynasty® 280 DX Multiprocess welder provides portability and ultimate versatility to weld many different materials.
Read More
5 Tips to Determine the True Cost of Field Welding
Identifying common hidden costs in your field welding operation can help keep your project on time and on budget.
Read More
Easily Switch Polarity in Welding Applications With New Technology
Welders can change welding processes and polarity with the push of a button at the weld joint — saving significant time.
Read More
Remote Control Welding Technology Offers Benefits for Productivity Quality and Safety
Remote control technology provides welding operators with the ability to set welding parameters at the joint, increasing safety by reducing trips to and from the power source, and increasing arc-on time for greater productivity. This technology also helps improve quality by eliminating the need to settle for less-than-optimal settings.
Read More
6 Tips To Improve Welding Productivity on Construction Jobsites
Using more efficient welding processes and technologies can help contractors complete jobs faster and compete for more bids.
Read More
How to Update Software on Your Miller Engine-Driven Welder
Follow these quick step-by-step instructions to update the software on your Miller® engine-driven welder.
ArcReach® Technology: Don’t Walk. Weld.
Don’t walk to the power source to adjust weld parameters. Do it at the weld joint with ArcReach technology.
How to Set Dynamic DIG Parameters for Pipeline Welding
Local 798 pipeline welder Tyler Sasse shows how to set Dynamic DIG parameters for high-quality pipeline welds.
Stick Welding With Multimatic 255
Set up your Multimatic® 255 multiprocess welder for the stick process quickly and easily with these instructions.
UA Local 67 Welds Carbon Steel Schedule 40 Pipe
Second-year UA Local 67 apprentices Alicia Komejan and Shaun Goulbourne, along with Certified Welding Instructor Steve Knapp, discuss welding carbon steel schedule 40 pipe.
Welding Leads Best Practices for Pipeline Welders
Faulty welding leads is one of the most common problems in pipeline welding. Learn how to maintain weld cables for optimal results.
ArcReach Welding Technology Offers Benefits for Safety, Productivity and Quality
ArcReach remote control technology provides operators with the ability to set welding parameters at joint, and increases arc-on time for greater productivity.
Avoid Voltage Drop to Improve Weld Quality on Jobsites
Voltage drop can cause poor weld quality and costly rework. Learn more about what causes voltage drop and how to prevent it.
60-Sec Tech: Auto-Process Select™
Learn how Auto-Process Select technology on the XMT® 350 FieldPro™ multiprocess welder can save you time and money.
Downhill Welding Tips: Setting Arc Control vs. DIG Range
Arc control and DIG range parameters are critical in downhill pipe welding. Learn how to achieve the optimal settings.
Tips to Increase Productivity in the Field with Wire Processes
Wire welding processes offer significant benefits that make them a frequent choice for welding jobs in the fabrication shop, including high weld quality.
Discussion Forums
Join the discussions in any of our 3 forums
