Metal Cutting Guide - How-To | MillerWelds
Metal Cutting Guide
Check out our step-by-step Plasma Cutting tips and training materials, and watch videos to improve your plasma cutting skills.
Articles and Videos
Choosing Between Plasma Cutting and Oxy-fuel Systems
What are the advantages and disadvantages of oxy-fuel torches vs. plasma cutting systems? Learn more about how to choose the right one for your needs.
Read More
Oxy-Acetylene Welding 101
Welding is a fundamental skill needed for many truck modifications and repairs. Once a person can cut metal and join parts by welding, an entire universe of possibilities will open for you. This is the start of a four-part series, which will give an overview of the most popular cutting and welding processes.
Read More
8 Tips for Using a Plasma Cutter in Custom Car Builds
Ensure proper plasma cutter settings with a sample cut and use faster travel speeds for cleaner cuts. Read more plasma cutting tips.
Read More
Tech Tips For Better Plasma Cutting
Learn the basics of plasma cutting and explore such topics as set-up, operation, and application considerations for Miller's Spectrum® plasma cutters.
Read More
Plasma Cutting Safety Makes Sense
Plasma cutting is easy and extremely efficient, but is not without its hazards: electricity, gas, ultraviolet light, etc. This article details a few key safety factors to consider before striking an arc.
Read More
Making the Cut: Plasma Cutting For Home Repair and Hobby
Learn how to select and operate a plasma cutter for a variety of DIY projects.
Read More
Hand-Held Plasma Cutters - A Selection Guide
Read More
How To Select and Operate a Hand-Held Plasma Cutter [Guide]
Before you strike an arc, learn more about choosing a plasma cutter and accessories that best match your application.
Read More
Weekend How-To: Floor Pan Replacement, Welding and Protection
One of the most common projects in automotive repair and restoration is the replacement of a rusted-out floor pan. Andrew White, owner of Apex Autosports, provides rust prevention advice and shares tips for plasma cutting and MIG welding in his walk-through of the restoration process on a 1975 Volkswagen Super Beetle.
Read More
Hand Tighten Oxy-Fuel Torch Attachments
Miller® | Smith® makes it easy to change torch attachments. Only needing to hand tighten the attachment, torch attachments are quickly changed with no wrench required.
360 Degree Torch Attachment Turn
Removing a Ball Hitch with an Oxy-Fuel Heating Tip
Watch the Miller® | Smith® Toughcut™ torch in action as it removes a ball hitch using a heating tip.
Bending Rebar with an Oxy-Fuel Heating Tip
How to Prevent Reverse Flow in an Oxy-Fuel Torch
Watch these step by step instructions to learn how to prevent reverse flow in your oxy fuel torch which could lead to a flashback.
How To Light, Set and Extinguish an Oxy-Fuel Torch Flame
Watch these step by step instructions to learn how to safely light, set and extinguish and oxy-fuel torch flame.
How To Safely Setup an Oxy-Fuel Torch Outfit
Watch these step by step instructions to learn how to safely setup an oxy-fuel torch outfit before using.
Graf-Tite™ Soft Seat Tip Change
The graf-tite™ soft seat tip design by Miller® | Smith® makes changing tips faster and easier as it conforms to imperfect surfaces.
How to Identify an Oxy-Fuel Torch Backfire and Shutdown
Watch these step by step instructions to learn how to identify the properties that can create a sustained backfire in an oxy-fuel torch and how to shutdown your oxy-fuel system in case of a sustained backfire.
Easy Oxy-Fuel Tip Cleaning
Graf-Tite™ Soft Seat Tip Proper Seating
Plasma vs. Oxy-Fuel: Which Metal Cutting Option Is Right for You?
Plasma vs. Oxy-Fuel: Which metal cutting option is right for you? This discussion covers all angles on the question for metal cutting in different applications.
Discussion Forums
Join the discussions in any of our 3 forums.
