Induction heating tool options
When welding applications require preheat, choosing the right solution can save money, improve safety and boost productivity. Selecting the type of heating process you need is the first step; the next is choosing heating tools that are compatible with your applications.
Induction heating technology offers significant advantages for efficiency, consistency and safety compared to open-flame or resistance heating methods. In the past, liquid-cooled cables — which require a cooler and insulation — were the most widely available flexible heating cable option for pipes, flat plate or oddly shaped parts.
Air-cooled cables, a new heating tool for induction, deliver the same flexibility as liquid-cooled cables without the need for a cooler or liquid-cooled cable connections. This can save time and eliminate some costs in preheat applications.
What is induction heating used for?
Induction heating provides many well-documented benefits for preheating in both shop and field applications. It’s a power-source-driven process that quickly brings a part to temperature and holds it there. It offers advantages for safety, quality and efficiency not found in open-flame and resistance heating methods.
Induction heating systems quickly heat ferrous metals such as alloy steel, carbon steel, cast iron and wrought iron by inducing current into the part. Induction does not rely on a heating element or flame to transfer heat. Instead, an alternating current passes through the heating device, creating an alternating magnetic field around it. As the magnetic field passes through the workpiece, it creates eddy currents within the part. The resistance of the metal fights against the flow of the eddy currents, generating heat in the part. The part becomes its own heating element, heating from within, which makes induction very efficient since little heat is lost in the process. Applications that typically require hours to heat can be completed in minutes by utilizing induction heating.
When using open-flame heating, temperatures are typically monitored manually using temperature crayons, which measure temperatures in 25-degree increments. In comparison, induction systems use feedback from thermocouples for exact temperature readings and uniform temperature control.
New induction heating tool
Most welding preheat applications that are performed using air-cooled blankets or liquid-cooled cables can use the air-cooled cables from Miller Electric Mfg. LLC. Air-cooled cables eliminate liquid cooling requirements while still providing a flexible and efficient solution for welding preheat.
Welding preheat is often completed on carbon steel that is heated up to 400 degrees Fahrenheit (204 degrees Celsius). The air-cooled cables, used with the ProHeat™ 35 induction power source, are rated for up to 400 degrees Fahrenheit in the heating zones around the weld, and they can be used with pipe diameters of 3/4 inch and up. The cables have amperage capabilities of 250 amps maximum and 200 amps continuous.
In addition, the flexible cables can be bent or shaped to best fit the pipe, flat plate or part to be welded, so they’re a solution that can meet many preheating needs.
No cooler required
While liquid-cooled cables for induction heating are easy to set up and provide flexibility for preheating, they may not be suited for every operation because of the potential risks associated with cable freezing or spilling coolant on the jobsite.
The glycol solution in the coolant does prevent freezing in environments down to minus 10 degrees Fahrenheit (minus 23 degrees Celsius), but an issue arises when preheating in extremely cold environments, such as pipeline jobsites in Alaska, Russia or Canada. Liquid-cooled cables must be kept in a heated environment above these temperatures to prevent freezing, which adds time and an additional step to the process. With air-cooled cables, no cooling liquid means no risk of freezing.
Because they don’t require cooler or coolant connections, air-cooled cables provide the same benefits for flexibility and easy setup without the concerns about losing or damaging connection hoses, damaging coolant connectors on heating cables, or spilling coolant on workpieces or in the work environment.
In addition, operations save money when they eliminate the need to buy a cooler and the maintenance for the unit. This also reduces the weight of the induction heating system.
No additional insulation needed for some applications
When using liquid-cooled cables, it’s recommended to use added insulation when preheating material above 200 degrees Fahrenheit (93 degrees Celsius). This will prevent the coolant from overheating in the case when coolant flow is turned off while on a hot workpiece.
The air-cooled cables are designed with materials that can withstand higher temperatures with no coolant, so they can be applied directly onto the material being heated up to 302 degrees Fahrenheit (150 degrees Celsius). Air-cooled cables can be used on heating applications to 400 degrees Fahrenheit with 1/2-inch preheat insulation, while liquid-cooled can go to 1,400 degrees with proper insulation.
