Your engine drive is a workhorse that lets you complete a wide range of jobs in the field — from multiprocess welding and gouging to powering tools and lights. But the need to frequently adjust weld settings or switch between welding processes can be a hassle when you have to walk back to the welder/generator each time or if you have an unreliable accessory.
When operators can easily adjust weld settings right where they’re working by using a remote pendant or wire feeder that provides communication back to the power source, it can save significant time and money, especially on large jobsites where there are many tasks to be completed.
So how do you know which options can best meet your needs and help you complete jobs efficiently? Keep these factors in mind when choosing an engine drive and accessories for the jobsite.
Binding reliability and speed
Having an engine drive and stick/TIG remote accessory that aren’t binding easily and reliably is a hassle that wastes time and keeps you from getting work done — and it reduces the effectiveness of the accessory. Poor connectivity between the engine drive and the accessory makes the accessory essentially unusable. You need reliable equipment that works when you need it to get the job done.
A Miller® ArcReach® stick/TIG remote binds quickly and consistently to Miller engine drives with ArcReach technology, so you start work immediately.
Process selection and changes at the accessory
If a remote pendant or wire feeder doesn’t provide the ability to select and change your welding processes at the point of the work — forcing you to walk back to the power source to make those adjustments — you don’t have the ability to maximize the convenience of the technology.
Some systems will automatically choose the correct process based on how the machine is set up. Auto-Process Select™ technology from Miller detects electrode polarity as well as the ArcReach accessory being used and will set the welding power source to the correct process.
Look for engine drive accessories that let you toggle between direct current electrode positive (DCEP) processes such as xx10, xx18 and gouging on the remote pendant. When configured in direct current electrode negative (DCEN), the remote will automatically select the TIG process. Likewise, the ArcReach feeder detects the polarity configuration to automatically select either the DCEP MIG/FCAW-G or DCEN FCAW-S process.
Adjusting arc control at the accessory
Not all technologies for the jobsite were created equal, and most are limited in their ability to fine-tune the arc remotely.
When engine drive accessories lack this capability, welders might make do with less than optimal arc control settings rather than walk back to the power source to make adjustments. It can seem like a time saver, but it can result in weld quality issues or even rework.
Arc control through an ArcReach accessory — available on all ArcReach Trailblazer® and Big Blue® welder/generators — provides precise arc control (also known as dig), allowing you to fine-tune the arc. If you encounter a tight root fit-up or need to weld out of position, turning up the arc control on the stick/TIG remote will match the application by providing a stiff arc. Then during fill and cap passes or when welding in the flat position, the arc control can be lowered — without making the trip back to the power source — for minimal spatter and desirable wetting at the toes to create an excellent-quality finished weld.
Having arc control allows you to match your welding preferences and quickly dial in the proper parameters using the remote — to optimize weld quality and maximize productivity. This delivers more flexibility and greater control.
