Versatile Work Truck Fleet Helps Freshour Precision Meet Customer Needs | MillerWelds
Share
A work truck needs the right tools to tackle any job. For Freshour Precision, Miller engine-driven welders are key for equipment repair.
Work truck technician makes equipment repair
Work truck repairs in the field
Miller® Trailblazer® critical for repairs
With years of experience as a mechanic, welder and fabricator, Willie Freshour decided to strike out and start his own business. Freshour had worked as a heavy equipment mechanic, a welder in traditional manufacturing and a fabricator building off-road race cars. He had the experience and the basic equipment in his home garage to launch Freshour Precision.
“The decision to work for myself was as easy as quitting my job and going to work in my garage at first,” Freshour says.
As the business steadily grew in the first two years, Freshour realized it was time for a larger location. He bought a farmstead near Hortonville, Wisconsin, with his wife and began rebuilding the old machine shed as the new home for Freshour Precision.
“Before I even had the building done, all of the sudden I had like five employees, and I didn’t even have a sign out yet.”
Solving problems with metal
The business swelled to 20 employees at one point, but Freshour decided he preferred a smaller operation that allows him to maintain more control over jobs and quality. Now back to four employees in addition to Freshour and his wife Angela, the business focuses on welding, fabrication and repair for farming, construction, industrial and heavy equipment customers.
“It became apparent that farmers and customers with heavy equipment have constant needs, so we set up our shop for them,” Freshour says. “They need their equipment to keep working, and they want it done as fast as possible.”
Freshour enjoys that hustle and the gratitude of customers when he saves them money by reducing their downtime.
“They are losing money by the minute and we stop the bleeding. I really like that part.”
Designed as a one-stop business, Freshour Precision can machine and weld parts in the shop and also make repairs and complete installation on customer jobsites thanks to a fleet of work trucks.
“We can help with projects from start to finish,” Freshour says. “We solve problems with metal.”
Versatile truck fleet
The company’s work truck fleet is constantly changing as older trucks are replaced with newer models. The fleet typically totals seven or so trucks, with most work happening during spring, summer and fall. In the summer, the business can have six or seven trucks running every day for weeks.
Trucks in the fleet range in age from 1986 to 2018 models. Freshour prefers Ford Super Duty trucks because they have heavy-duty chassis and are available in different sizes, and he’s had good luck with maintenance. He buys a lot of class 5 trucks, which provide plenty of cargo room and hauling capacity for welding gear and other accessories.
“Fully loaded, it might weigh 14,000 pounds, but you can still hook up a trailer and throw a big telehandler on it, load a bunch of steel on the roof rack, and still safely drive down the road,” Freshour says.
Outfitting the truck with the right accessories is important. Freshour and his employees frequently reorganize their work trucks to maximize space. Along with having an engine-driven welder on every vehicle, key accessories include mechanic tools, rigging, an air-arc setup, grinding tools and come-alongs. The trucks also carry ladders, personal protective gear and safety equipment for fall protection.
During the busy season, some trucks are built out lighter, and those are typically used on new construction jobsites. Other vehicles in the fleet are more heavily stocked with equipment and tools, and those are designed for repair work.
“When you’re doing emergency repair work, you have to bring everything but the kitchen sink,” Freshour says. “Repair work is very unpredictable.”
Welding is critical
Choosing the right engine-driven welder is key to completing a wide variety of jobs. Freshour typically wants an engine-driven welders that can power two welders simultaneously and weld up to 3-inch-thick plates. The company mostly stick welds on customer jobsites but also needs the capabilities and tools to weld with wire when the application calls for it.
“The heart of the whole operation is the engine-driven welder,” Freshour says. “As soon as you throw one on the back of a flatbed, you have a service truck.”
The Miller® Trailblazer® 325 gas engine-driven welder is a favorite for Freshour Precision. It offers fuel efficiency and reduced engine noise for a quieter jobsite. And the compact design provides space savings so there’s plenty of room on the truck for other tools and gear.
“If you’re welding with 1/8-inch 7018 electrodes, another guy can plug in with another inverter machine and weld with 1/8-inch electrodes, and the Trailblazer has plenty of power for that,” Freshour says.
The company’s mechanic-only truck also includes a crane body, so that truck has a Bobcat™ 200 Air Pak™ engine-driven welder on board. The rotary-screw air compressor can power air tools, including most impact wrenches, supplying 28 cfm at 175 psi and 100 percent duty cycle.
Staying on top of fleet maintenance
The slower winter months are a good time for Freshour Precision to thoroughly inspect the trucks and reorganize them as needed. But it’s also important to stay on top of truck and engine-driven welder maintenance during the busier seasons.
“In the summer when the trucks run all week and drive a few hundred miles a day, we might spend all weekend maintaining the trucks. Just keeping up with oil changes is hard,” Freshour says. “But you can’t run your truck that many miles and your welder all day and not maintain it, or you’ll run into problems.”
Freshour knows that staying on top of regular maintenance — even during the busiest seasons — is key to keeping his busy fleet on the road to serve customers. He also suggests not using work trucks as personal vehicles, which helps limit the wear and tear on them.
Investing in quality equipment and tools — and taking the time for proper maintenance — are keys to success for Freshour Precision.
Published:
