DIY Welding Project: Holiday Metal Tree Sculpture [Guide] | MillerWelds
Share
This metal tree sculpture will bring winter spirit and holiday joy for years to come. Weld your own with these instructions.
SKILL LEVEL: Beginner
TIME COMMITMENT: 6–8 hours
Here's what you'll need to get started.
TOOLS AND MATERIALS
Spectrum® 625 X-TREME™ plasma cutter
Multimatic® 220 AC/DC multiprocess welder
36" x 48" 16-gauge steel (or similar thickness)
3/8" all-thread/ threaded rod (approx. 18" to 20" long)
3/8" acorn nut
3/8" coupler nut
3/8" standard nut
1/4" washer
Dead blow hammer
6" diameter cutting disk (used as pattern for base)
Sheet metal pliers (or a couple crescent wrenches)
Bandsaw (or laser cutter)
Flap wheel
WARNING: READ AND FOLLOW ALL LABELS AND THE OWNER'S MANUAL.
STEP BY STEP
Cutting metal tree section patterns from wood
STEP ONE:
Print and/or cut out the patterns for the tree. For this project, I used a laser cutter, but you could use a bandsaw.
split screen showing clamping wood pattern pieces to metal and close-up of plasma cutting pattern into metal
STEP TWO:
Take your 36" x 48" gauge steel and affix or clamp the patterns to the material. Note that the physical patterns are offset for the Miller® drag tip (30 or 40 amp). Each part requires two patterns — one for the inner profile and one for the outer profile. Pierce and slowly drag along the profile using your plasma cutter. Repeat until all pieces are cut out.
Close-up of grinder with flap wheel grinding sheet metal edges
STEP THREE:
Using a flap wheel, grind and deburr the underside.
Welder using orange dead blow hammer to pre-crease folds into metal over angle iron
STEP FOUR:
Using a piece of angle iron and a dead blow hammer, pre-crease the folds as shown. This step will make the bends more crisp. Since the metal is so thin, most work can be done with your hands.
Welder using sheet metal pliers to bend metal tree sections
STEP FIVE:
Begin bending the sheets into shape using either sheet metal pliers or a crescent wrench.
Welder preparing to tack weld inner and outer folds of tree sections together
STEP SIX:
When the folds line up, tack weld them into place using your Multimatic 220 AC/DC. Tack on the top side for the inner folds and on the bottom side for the outer folds. Repeat this process for all of the pieces.
Welded metal tree sections stacked on top of each other to create tree form
STEP SEVEN:
Once the shape is almost complete, finish welding the seam together and place a tack on the tip. Attempt to make the same tack on the tips of each star. When done, each piece should nest on top of each other as shown. These shapes will be rotated 45 degrees to create a tree.
Operator plasma cutting around pattern
STEP EIGHT:
To create the base for the tree, cut a 6" diameter circle from the 16-gauge steel.
Close-up of operator using MIG gun to tack weld nut to metal disk
STEP NINE:
Next, weld a 3/8" coupler nut in the center of the disk/base. This will accept the 3/8" all-thread that will form the structure of the tree.
Metal tree stand in progress
STEP TEN:
Then, place a nut on the all-thread in order to lift the tree off the ground. A 1/4" washer is a tight fit on the all-thread and will provide uniform support to the bottom section.
Metal tree sections stacked on top of each other
STEP ELEVEN:
Stack each section of the tree on the rod, rotating each section 45 degrees to the section below. By stacking on the rod — rather than welding each section together — you can easily unstack and store. However you could also weld each section together and forego the rod if that’s your preference!
Welder marking rod above nut with marker
STEP TWELVE:
With the sections appropriately added and compressed with a standard nut at the top, the rod is marked. Use a hacksaw (or portaband) to cut the rod to length.
Close-up of acorn nut affixed to top of metal tree
STEP THIRTEEN:
Top the rod with an acorn nut. How it is finished is up to you  — some like the raw steel look while others might paint it green or white. I can imagine an orange rusted version might look great or even a copper tree with a green patina.
About Brian Oltrogge
Brian Oltrogge headshot
Brian Oltrogge is the owner of Grunblau Machine, LLC and Grunblau Design Studio. Brian was trained as an architect and has taught at various institutions, including LTU, Cranbrook, RPI and College for Creative Studies in Detroit. Over the last 25+ years, he has worked as an architectural designer and fabricator whose work has been featured in various architectural publications, including Dwell Magazine. His work is also included in the permanent collection at the Museum of Modern Art. Brian uses Youtube as a platform for showcasing his ideas and expressing his creative energy in the hopes of educating and inspiring others to follow their passion and make something!
Published:
