Work Truck Equipment Selection [GUIDE] | MillerWelds
How to Select the Best Solution for Your Truck
Having the right equipment on your truck is critical to getting jobs done. Miller offers a full portfolio of solutions that deliver the power for any jobsite need and are equipped with industry-exclusive technologies — to help you save time and money and reduce unnecessary truck engine hours. Select your configuration below to discover the options for your operation.
Mechanic
Illustration of a Lube Work Truck
Responding to repairs on a tight deadline, you need versatile equipment you can depend on. Whether you need to refill tires, give a jump-start, charge a battery or weld to get your customer back to work, you require a solution that helps you quickly tackle whatever job you encounter.
Service
When vital services are down, you need a reliable solution so you can respond quickly. Whether you’re fixing a broken water pipe, completing a roadside repair or keeping a customer’s fleet running, an air compressor and generator are critical for powering the tools that help you get the job done.
Lube
You’re busy maintaining equipment, so you want to avoid downtime and unplanned maintenance to keep your work on schedule. Whether the job involves changing the oil or greasing components on heavy equipment, you’re running multiple functions at once, which requires reliable generator, air and hydraulic power.
A graphic of an Instagram post featuring a work truck next to Miller swag
Enter the #Ready4AnythingSweeps!
Post a picture of your always-ready Miller® equipment on Instagram and you could win a YETI® water bottle and hat! Be sure to tag @millerwelders, use #Ready4AnythingSweeps, and post no later than midnight CT, March 31.
See Official Rules >
Resources
To maximize efficiency and productivity, you need to stay current on the latest work truck trends and technologies. Here’s where you can find helpful articles and videos that cover work truck equipment, fleet management, problem solving and more.
