Product Selection Guide | MillerWelds
Help Me Choose the Right Product
Finding the equipment that's right for you doesn't have to be complicated.  Follow the steps below.
1. Select the right process
Welding Processes
The most common welding processes are Shielded Metal Arc Welding (SMAW or Stick electrode), Gas Metal Arc Welding (GMAW or MIG, a wire welding process), Flux Cored Arc Welding (FCAW, also a wire welding process) and Gas Tungsten Arc Welding (GTAW or TIG). The two most common cutting and gouging processes are Air Carbon Arc Gouging (CAC) and Air Plasma Arc Cutting (plasma).
Note that:
  • MIG and flux cored welding usually can be performed by the same machine (and sometimes pulsed MIG)
  • TIG machines can usually Stick weld (and vice versa)
  • Higher output Stick machines can also air carbon arc cut and gouge
  • A multiprocess welding machine might be able to perform all of these processes!
MIG Wire (GMAW)
Skill Level: Low
Operating Cost (time and materials): Low
Metals: Steel, Stainless Steel, Nickel Alloys, Aluminum and Copper/Brass
Metal Thickness:  24 gauge (.025") and up
Speed: Very fast
  • Easiest process to learn
  • High welding speeds possible
  • Better control on thinner metals
  • Cleaner welds possible with no slag
  • Same equipment can be used for Flux-Cored Welding
Learn more about the MIG welding process >>
Pulsed MIG Wire (GMAW-P)
Skill Level: Low
Speed: Very fast
  • Flexibility and productivity - nearly all metals can be welded in all positions
  • Larger diameter electrode wires for higher deposition rates
  • Virtually no spatter
  • Welds thin to thick metals
Flux Cored Wire (FCAW)
Skill Level: Low
Metal Thickness:  1/8" and up
Speed: Very fast
  • Can works as well as Stick on dirty or rusty material
  • Out-of-position welding
  • Deep penetration for welding thick sections
  • Increased metal deposition rate
Stick (SMAW)
Skill Level: Moderate
Operating Cost (time and materials): High
Metals: Steel, Stainless Steel, Nickel Alloys and Copper/Brass
Speed: Slow
  • Well suited for windy, outdoor conditions
  • More forgiving when welding on dirty or rusty metal
Learn more about the Stick welding process >>
TIG (GTAW)
Skill Level: High
Metals AC: Aluminum and Magnesium Alloys
Metals DC: Steel, Stainless Steel, Nickel Alloys, Copper/Brass and Titanium
Metal Thickness:  .010" and up
Speed: Very slow
  • Provides highest quality and most precise welds
  • Highly aesthetic weld beads
  • Allows adjustment of heat input while welding by use of a remote control
Learn more about the TIG welding process >>
Pulsed TIG (GTAW-P)
Skill Level: High
Speed: Very slow
  • More control on thin metals
  • Less heat distortion on thin metals
Resistance Spot Welding
Skill Level: Low
Metals: Steel, Stainless Steel and Nickel Alloys
  • Simple, easy-to-operate welder for light industrial applications
Learn more about Resistance Spot Welding >>
Submerged Arc (SAW)
Metals: Steel and Stainless Steel
  • High deposition rates can enhance weld speed and production
  • Excellent mechanical properties for high-quality code and X-ray requirements
  • Improves welding operator comfort and appeal — arc is below a bed of flux
Cutting Processes
Plasma Arc Cutting & Gouging (PAC)
Skill Level: Low
Metals: All Electrically Conductive Metals
Metal Thickness:  Up to 7/8"
Speed: Very fast
  • Use with any electrically conductive metals
  • Small and precise cut
  • Small heat-affected zone which helps prevent warping or paint damage
Learn more about Spectrum Plasma Cutters >>
Oxy-Fuel Cutting
Skill Level: Low
Metals: Steel
Metal Thickness:  Up to 8"
  • Cuts ferrous (containing iron) steels
  • Requires no electricity
  • Highly portable
  • Can also be used for welding, heating, brazing and soldering
Learn more about metal cutting processes >>
Air Carbon Arc Cutting & Gouging (CAC-A)
Operating Cost (time and materials): Moderate
Metals AC: Copper and Brass
Metals DC: Steel, Stainless Steel, Aluminum and Cast Iron
Metal Thickness:  Unlimited
Speed: Fast
  • Wide variety of metals
  • Removes discontinuities or inferior welds
2. Evaluate Your Needs: Power and Portability
Input power
Does your machine need to be self-powered, or will AC power be available at the location where it’s primarily used?
  • For locations where an electrical hookup is not practical, consider a gas- or diesel-powered engine-driven welder/generator to supply welding and generator power.
  • For locations where AC power is available, you need to know its type—and whether it’s a match for the machine you’re considering:
    Single-phase power is found in most homes and garages. Check to see if the machine you’re considering requires single-phase power, and whether its voltage requirements (120 or 240 volts) are met by the electrical service at the intended location.
    Three-phase power is common in industrial settings. Check to see if the machine you’re considering requires three-phase power and whether its voltage requirements are met by the electrical service at the intended location.
About duty cycles
Duty cycle is an indication of how long a power source can continuously weld (at a specific amperage and voltage) in a 10-minute period of time before it needs to cool down. For example, a machine with a 60 percent duty cycle at 300 amps and 32 volts of welding output can be used (at 300 amps and 32 volts) for 6 minutes out of a 10-minute period. When comparing two similarsized power supplies it is important to pay close attention to both the amperage and voltage values that determine the rated load.
When considering duty cycle for a Stick machine, note that most Stick electrodes are consumed in less than two minutes. Further about 80% of all Stick welding is done with a 1/8-inch diameter electrode, which takes about one minute to consume.
To see if a machine meets your needs, consider the following power classifications.
  • Light Industrial products typically have a 20% duty cycle and a rated output of 230 amps or lower.
  • Industrial products typically have a 40-60% duty cycle and a rated output of 300 amps or lower.
  • Heavy Industrial products typically have a 60-100% duty cycle and a rated output of at least 300 amps.
Generator power
Out in the field, you may need an engine-driven welder/generator to supply 120- or 240-volt AC power to run tools and lights, or supply 12-volt DC power to charge automotive batteries and jump-start vehicles. Miller welder/generators are packed with power; larger units even offer option packages that add 10 to 20 kW of generator power.
Learn more about generator power requirements >>
Portability
Can you bring the work to the machine, or does the machine need to go to the work? Check the product detail pages for types of portability:
  • Shoulder strap, handles, running gear, carts, etc.
  • Many engine-driven welding generators fit in the back of a pickup truck, enabling them to be driven to wherever the welding is needed. Heavy-duty trailers are also available for engine drives.
