High-Vacuum Fume Extraction: FILTAIR® 215 Fume Extractor | MillerWelds
FILTAIR® 215
FUME EXTRACTOR
BUILT FOR MULTI-TASKING
FILTAIR® 215 is a versatile, high-vacuum fume extractor that captures weld fume at the source. With maximum airflow capacity, multiple operators can use portable extraction attachments such as nozzles and fume guns for efficient, multi-use weld fume capture in a variety of applications.
Optical Airflow Icon
OPTIMAL
AIRFLOW
An airflow rating of 215 CFM. provides effective fume capture with multiple attachments.
Multi-Gun Performance Icon
MULTI-GUN PERFORMANCE
Run multiple accessories simultaneously without sacrificing weld fume capture.
Variable Flow Control Icon
VARIABLE FLOW CONTROL
Airflow can be adjusted to fit specific applications and accessories.
Slef-Cleaning Filter Mechanism Icon
SELF-CLEANING FILTER MECHANISM
A pulse cleaning cycle is automatically activated when needed, extending filter life by 8x.
FILTAIR® 215
FEATURES
OPTIMAL PERFORMANCE
VERSATILE SOLUTION
SIMPLIFIED MAINTENANCE
DURABLE DESIGN
Optimal Performance
Versatile Solution
SimplifiedMaintenance
Durable Design
FUME EXTRACTION SOLUTIONS
Our complete line of FILTAIR® fume extractors are designed specifically for welding, drawing weld fumes away from the user’s breathing zone and keeping your facility clean.
