All New, All-Miller® Copilot™ Cobot | MillerWelds
THE ALL-NEW, ALL-MILLER™ COPILOT™ COBOT
The easiest, most intuitive welding cobot
You, Amplified
Advancing your skills doesn't have to be complicated. Miller has made welding automation easier than ever with the all-new Miller Copilot Cobot. No complex software to slow you down, no barriers to training new operators and no reason not to evolve your workforce.
Yellow icon of a stopwatch
Ease of Use
Easy to learn and operate, Copilot Cobot removes complexity so that welders of all skill levels can be up and running within hours.
AccuGuide™
Precision Joystick
Our Copilot Cobots AccuGuide™ provides fingertip control for pinpoint torch positioning and perfect weld setting. Easy to learn. Easy to use.
IntelliSet™ Weld Settings Assistant*
The most simple, intuitive interface and software empowers welders of any skill level to confidently produce repeatable, high-quality welds within minutes.
High-Mix, Low-Volume
Quickly and easily improve quality and increase throughput for high-mix, low-volume parts production to keep up with demand.
The Copilot Collaborative Welding System’s welder-centric design responds the way a welder would want it to — without complex software or clunky controls to slow you down. Every welder can quickly and easily advance the way they work to strengthen your operation.
Miller Collaborative Welding System
Copilot™ Cobot AccuGuide™ Precision Joystick
In addition to the typical cobot free drive movement, while programming, AccuGuide simplifies precise positioning and adjustment to produce the most accurate welds.
Copilot™ Cobot IntelliSet™ Weld Settings Assistant*
Simply input the material thickness and the wire diameter. IntelliSet, Miller’s intuitive software, configures the weld settings together with the selections from the Auto-Continuum power source. You’ll experience the fastest, most productive weld programming platform, streamlining weld setting assignments for easy learning and quick changeovers.
Large Work Table
  • Robust 48" x 48" work table with 42" x 30" hole pattern.
  • Up to 1,500-pound payload capacity
  • Tooling hole pattern compatible with most modular fixturing
Power Supply
  • Auto-Continuum™ 350 power supply with advanced welding capabilities (907656)
  • Durable and reliable for everyday welding challenges
  • Advanced capabilities like Accu-Pulse®, Versa-Pulse™ and RMD® processes to grow with your needs
*IntelliSet™ Weld Settings Assistant available for download in March 2023.
Stylized blue quotation mark
It’s very simple. There’s not a lot of bells and whistles that make it more confusing. It’s straightforward and you’re literally welding in minutes.
— Andy Horst,
Manufacturing Engineer at Franklin Fueling Systems
